Wyjscie S-videa W Karcie Graficznej
butcher
Skonfigurowalem sobie pliczek xorg.conf...mam tam wpisane dwa ekrany. Wszystko dziala tyle, ze na moim TV wyswietlany jest tylko czarno-bialy obraz!!!!
Jak ten problem nalezy rozwiazac??W semie to mam jeszcze kiepska czestotliwosc odswiezania i glebia kolorow....Glebie mozna chyba zmienic w sekcji Sreen : Depth 24, a czestotliwosc w sekcji Monitor : HorizSync 30.0-50.0
VertRefresh 60 ????
Tak wyglada moj pliczek xorg.conf :
Section "Files"
# RgbPath is the location of the RGB database. Note, this is the name of the
# file minus the extension (like ".txt" or ".db"). There is normally
# no need to change the default.
# Multiple FontPath entries are allowed (they are concatenated together)
# By default, Red Hat 6.0 and later now use a font server independent of
# the X server to render fonts.
RgbPath "/usr/X11R6/lib/X11/rgb"
FontPath "unix/:7100"
EndSection
Section "Module"
Load "dbe"
Load "extmod"
Load "fbdevhw"
Load "glx"
Load "record"
Load "freetype"
Load "type1"
# Load "dri"
EndSection
Section "InputDevice"
# Specify which keyboard LEDs can be user-controlled (eg, with xset(1))
# Option "Xleds" "1 2 3"
# To disable the XKEYBOARD extension, uncomment XkbDisable.
# Option "XkbDisable"
# To customise the XKB settings to suit your keyboard, modify the
# lines below (which are the defaults). For example, for a non-U.S.
# keyboard, you will probably want to use:
# Option "XkbModel" "pc102"
# If you have a US Microsoft Natural keyboard, you can use:
# Option "XkbModel" "microsoft"
# Then to change the language, change the Layout setting.
# For example, a german layout can be obtained with:
# Option "XkbLayout" "de"
# or:
# Option "XkbVariant" "nodeadkeys"
# If you'd like to switch the positions of your capslock and
# control keys, use:
# Option "XkbOptions" "ctrl:swapcaps"
# Or if you just want both to be control, use:
# Option "XkbOptions" "ctrl:nocaps"
Identifier "Keyboard0"
Driver "keyboard"
Option "XkbModel" "pc105"
Option "XkbLayout" "pl"
EndSection
Identifier "Mouse0"
Driver "mouse"
Option "Protocol" "IMPS/2"
Option "Device" "/dev/input/mice"
Option "ZAxisMapping" "4 5"
Option "Emulate3Buttons" "no"
EndSection
Section "Monitor"
Identifier "Monitor0"
VendorName "Monitor Vendor"
ModelName "StudioWorks"
DisplaySize 330 250
HorizSync 30.0 - 70.0
VertRefresh 50.0 - 160.0
Option "dpms"
EndSection
Section "Monitor"
Identifier "Monitor1"
HorizSync 30.0-50.0
VertRefresh 60
EndSection
Section "Device"
Identifier "Videocard0"
Driver "nvidia"
VendorName "Videocard vendor"
BoardName "NVIDIA GeForce 4 MX (generic)"
BusID "PCI:1:0:0"
Screen 0
Option "NoBandWidthTest"
EndSection
#Section "Device"
# Identifier "Videocard0"
# Driver "nvidia"
# BusID "PCI:1:0:0"
# Screen 0
#EndSection
Section "Device"
Identifier "Videocard1"
Driver "nvidia"
BusID "PCI:1:0:0"
Screen 1
Option "ConnectedMonitor" "TV"
EndSection
Section "Screen"
Identifier "Screen0"
Device "Videocard0"
Monitor "Monitor0"
DefaultDepth 24
SubSection "Display"
Viewport 0 0
Depth 16
Modes "800x600" "640x480"
EndSubSection
Viewport 0 0
Depth 24
Modes "1024x768" "800x600" "640x480"
EndSubSection
EndSection
Section "Screen"
Identifier "Screen1"
Device "Videocard1"
Monitor "Monitor1"
DefaultDepth 24
Depth 24
EndSubSection
EndSection
Section "ServerLayout"
Identifier "DefaultLayout"
Screen 0
"Screen0"
Screen 1
"Screen1"
RightOf
"Screen0"
InputDevice "Mouse0" "CorePointer"
InputDevice "Keyboard0" "CoreKeyboard"
EndSection
Section "DRI"
Group 0
Mode 0666
EndSection
Jesli dobrze rozumiem masz NVIDIA GeForce4. Wg mnie sprobuj ustawic kodowanie obrazu video w sekcji Device (TVStandard PAL-B). Moj xorg.conf:
Section "Device"
       Driver      "nvidia"
       VideoRam    65536
       Option      "TwinView" "1"
       Option      "SecondMonitorHorizSync" "30-50"
       Option      "SecondMonitorVertRefresh" "50"
       Option      "MetaModes" "1024x768_100Hz, 1024x768_50Hz; 1024x768, 1024x768_50Hz; 800x600, 800x600_50Hz; 640x480, 640x480_50Hz"
       Option      "TwinViewOrientation" "Clone"
       Option      "ConnectedMonitor" "CRT, TV"
       Option      "TVStandard" "PAL-B"
       Option      "TVOutFormat" "SVIDEO"
       Option      "NoLogo" "1"
EndSection
Mozesz tu pobrac caly xorg.conf (jeszcze jako XF86.conf)
To powinno zadzialac. MIlego ogladania :D
Ale numer!!!!Podlaczylem moja karte a drugim telewizorem i tam mam kolorory obraz!!!!Pierwszy telewizor nie ma wejscie S-video i kupilem taki zamiennik z Euro na S-video(W wyniku czego obraz mam czarno-bialy) Drugi TV ma juz standatdowo wyjscie S-video i na nim obraz jest kolorowy....
Moze wiecie czym mam sie kierowac kupujac taki zamiennik???Jak mam rozpoznac ten wlasciwy???
